9 members (lumbersawyer, sparky46, LAROKE, Otto Skorzeny, Gdads51, Woogeroo, Shade Baby, 68ironhead, Jon G), 143 guests, and 1 robot.
Topics128,104
Posts1,056,197
Members48,436
#929576 03/22/2013 10:58 AM
I have a 1953 216 engine that I am putting back together. Problem is the rope seal appears to be to thick so that when the cap bolts are tighten the crank does not turn freely. When I remove the seal and tighten the cap bolts the crank turns with little effort. I heard they make a neopreem replacement but all the auto parts stores and parts suppliers only carry the rope seal. Any suggestions?
Charlie
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
I'd try to locate a NOS original asbestos seal, on Ebay or try Langdon's Stovebolt. Also correct installation appears to be an art to get it right so read any tech tips on this you can find.
Best of luck
1946 1/2-Ton Chevy
Some people have reported that the Best Gasket seal is OK (but an original, asbestos seal is best).
I just used my first Best Gasket seal and would highly recommend it, even over NOS.
My Blog
I talked to Tom at Stovebolt and he suggested to get NOS with the asbestos rope seal for best results. I called Lester J Harris at 775-267-2559 and had it at my door in a few days. You may wish to give him a try. Mine was a 1956 235 motor.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Takes a little work (art) to get that seal properly worked into the channel. And it may seem pretty tight at first. Has to done right too or you may have problems with the main bearing cap seating correctly
Thanks for the info everybody, I ordered a Sneaky Pete rear main rope tool from the internet today. Hope to try installing the rear main again next week.
1953 5 Window
2006 Chevy Colarado
I used the Best rope seal and yes, the crank is tight with a new gasket. I assume it will wear in and be fine.
a full circle lip seal works better.
