0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Hello guys. My 1942 1.5 dump is leaking from the pto. Shaft seal, lever seal, ect. The brand is Central pto model 2b made in chelsea, Michigan. It drains the tranny within 24 hrs, so its bad. Of course all the local shops don't go back that far or never herd of that name. I'm sure I won't be able to get numbers off the seal so what can I do? Thanks, Mike. | | | | | Joined: Nov 2012 Posts: 15 New Guy | | New Guy Joined: Nov 2012 Posts: 15 | Measure the I.D. O.D. and width and any good seal and bearing shop should fix you right up. | | | | | Joined: Nov 2012 Posts: 15 New Guy | | New Guy Joined: Nov 2012 Posts: 15 | You do own a dial caliper, don't you? If not, get one. Also, with that level of wear you may need bearings as well as speedi-sleeves on the shafts. | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy alltruck72, the following seal numbers are for a Chelsea p.t.o., which is possibly what central became, these are CR numbers output shaft w/2.066" Seal O.D. p/n 12530 w/3.005" Seal O.D. p/n 21163 shifter shaft w/1.379" Seal O.D. p/n 6816 w/1.503" Seal O.D. p/n 8700 if these don't seem appropriate, just post the sizes you come up with and we'll see what we can come up with, hope that helps. | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Thanks guys, I'll be pulling the pto soon. | | |
