2 members (39Master85, 2Wheels),
105
Mod | | | Forums66 Topics128,196 Posts1,057,396 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Hey All, Tinkering on my 1955 3100 2nd series and need to know the correct location of the radio antenna. Was it in the passenger side cowl below the windshield or the passeger side fender. I have holes in each and need to patch one of them! I am thinking the cowl is correct but want to be positive!
Thanks, | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the fender is where it's located, a template was provided with the radio, guess yours got lost  Bill | | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | Be careful drilling, measure and check underneath.....several times. The antenna I got From fleabay had a template that looked like a photocopy. AFTER drilling I found the hole was behind the inner fender support not in front. Had it not been for some creativity and a Karmann Ghia antenna base I would have been in for some body and paint work. I ended up with a parts store top mount antenna with the Ghia angled chrome base. Looks fine but what a panic. | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | You need the accessories installation manual, I think it gives all the dimensions etc. It goes in the rh front fender and has bracketry that attaches to the plenum/cowl on that side. I'm going to try to figure out some other place for mine when I get one, or some other kind of antenna.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some other place for some other kind of antennaBill | | | | | Joined: Mar 2013 Posts: 30 New Guy | | New Guy Joined: Mar 2013 Posts: 30 | If you are installing a OEM type antenna, The placement is Critical on the fender. There is a slot in the cab for it to slide between cab and fender. | | |
