4 members (Jim K, tclederman, Lightholder's Dad, Biermann), 113 guests, and 0 robots.
Topics128,163
Posts1,056,918
Members48,458
I will be attempting to replace the rear rope cranshaft seal on my 1953 GMC engine. Althought the proceedure is well documented and states that the crankshaft needs to be loosen so that it can drop a bit to allow the rope seal to be install on the upper bearing. I need to know what the torque specification are when tightning the bolts. Also is there a pattern I should follow such as front to back or left to right??
Dan
3B Offline
Hy DJRoy, the torque listed in one of my Motors manuals is 100 - 110 ft. lbs., I couldn't find it in two maintenance manuals I checked, as far as a pattern is concerned I have always started in the center and then worked out, hope that helps.
When I replaced my main bearings, I dropped the crankshaft a fair amount. I found out that if I didn't let it down evenly it would hang up on the thrust bearing. Also it can damage the front seal but in my case I had the cover off. I also had to check that the timing marks were aligned when I pulled it back up into place. You shouldn't have to drop it that much.
1951 1 Ton Completed
