3 members (Chip O, Charles in CA, 1 invisible),
159
Mod | | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | I have a 1964 c10 and i just replaced the clutch, pressure plate, flywheel, and rebuilt the transmission and it won't move....it feels like it wants to move but it won't....i don't know if the clutch needs to be adjusted more or what but any help will be appreciated
Thanks | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Welcome Connor. We will see who jumps in on your question. If no one bites over the next few hours, try the drive line forum. Question sure to have responses there, if not here. Hambone | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Could be several things. Won't move in any gear including reverse? Probably clutch. Maybe your free play is too small. Should travel about an inch then feel resistance all the way down. Have someone push pedal while you watch linkage and clutch fork movement. Can you push truck while in gear? If you push in 3rd or 4th does eng turn over? Did you install Throw out brg backwards? Try extreme clutch adjustment until something different happens. If you rebuilt a standard transmission yourself, you must know what you are doing. Don't know what tranny you have but if it has linkage on the side like a car tranny/top loader, are they being shifted? Oh yes, install driveshaft.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | It shifts into reverse and first but not 2nd or 3rd...throwout bearing is installed properly and driveshaft is installed... I'll have to adjust the clutch some more and if that don't work then I'll figure it out eventually
Thanks for the help | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | What type pressure plate, finger or diaphram and long or short throw out bearing.
You Learn more Listening than Talking
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Please explain! "It shifts into 1st and rev". Does that mean the truck moves in those gears? Does that mean it won't physically go into 2nd or 3rd and also won't move in any gear? I know you said it won't move in your first post. Just making sure. Getting confused as to whether it's a clutch or an internal tranny problem, so please clarify shifting with clutch and movement of truck. It seems like you are done with this post? Is that correct?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | In first and reverse all it does is rev up and it will not shift into 2nd or 3rd | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Clutch, EDIT: see my next post.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Do you have ANY free movement when your clutch pedal is at the top of its swing? bartamos says 1 inch; I prefer about 3/8" to 1/4" but that is just different opinions. That free play tells you that the throwout bearing is not keeping the pressure plate depressed partly. Readjust your clutch and try again.
Best wishes,
Les | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The 55-59 maintenance manual says free play adjustment= 1". The 63 Chevy Truck manual says 3/4"-1". The 80-87 Chevy truck manual says 1 3/8"-1 5/8". In your case you need to try something to see if you can affect the engagement. Something is way off. The "no movement "indicates too small of a free play. The "not shifting" into some gears indicates too much free play. You may have two problems at the same time. Clutch and internal tranny. I assume you tested tranny before install to see that it shifted. BTW what tranny is it?
