9 members (Peggy M, Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, 1 invisible),
69
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | So I've called around looking for a u-joint repair kit for my 52' half ton and nobody has them in stock. Everyone says their on back order. Anyone know where I can find one? Thanks | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Have you tried your FLAPS? You will be surprised what you can find there.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Unfortunately my local "FLAPS" are all big chain stores that say their computers don't go back that far. I'm gonna stop by a transmission/drive shaft shop and see if they can fix my u joint. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | If I am looking for a part, I first check local FLAPS websites. In my area Advance Auto and Autozone are the most popular followed by NAPA. I go on their websites and look myself then arrive at the store with a part number. Takes all the frustration out dealing with the rookie behind the counter.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | So I've called around looking for a u-joint repair kit for my 52' half ton and nobody has them in stock. Everyone says their on back order. Anyone know where I can find one? Thanks 3-speed or 4-speed (important differences, if you need yokes)? What parts are you looking for? u-joint-cross & "caps"/bushings? | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Go to a NAPA and tell them to pull a book off the shelf. I was suprized at one of my local napa's it was a younger fella that knew the older stuff pretty good.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Finally found a supplier on ebay that had U joints in stock! Had to cancel my order today (ordered a month ago) from classicparts.com. Hopefully the manufacturer will get rolling again and get these u joints out to the big parts suppliers. I might order a second one just to have a back up in case something like this happens again in the future. | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | A note on compatibility. I have found that my 54 chevy pickup and 54 chevy sedan use the same u-joint and u-joint yoke that slides onto the drive shaft.
Walt Williams La Verkin, UT
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Walt,
Does your '54 sedan have a Powerglide transmission? Does you '54 truck have a Hydra-Matic transmission?
oldchevytrucks has not told us what transmission he has (or, u-joint parts he needs).
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | oldchevy trucks,
Sorry to hear about that. That kit is the easiest to find set of parts for a u-joint (Jim Carter and Chevs of the 40s, and I suppose other vendors have that kit). Some of the splined yokes are often harder to find.
Too bad no one posted a NAPA part number, so you could have gotten them locally. I could not find a set by searching NAPA.
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | I contacted every vender I could find including Jim Carters and Chevsofthe40s. I was surprised that not a single vender had the part. This is the first time I had this problem not being able to find a vender that actually had the part in stock. Almost everyone sells it, but nobody has it. The company on ebay I ordered from already has it shipped and on the way. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | good perseverance, oldchevytrucks
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | My experience with u-joints for the older stuff has been that the local store probably has them, but often you need to do one of two things: - If it is a relatively young person, make him take them off the shelf and match yours OR, if you get permission, do it yourself - Find an experienced (not necessarily old) person, they often can recite the part number from memory It's as Tim said, good perseverance. don
| | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | My sedan has a powerglide. My 3100 pickup has a 4 speed.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | My 1/2 ton 53 Chevy had a 4 speed transmission in it. The u-joint (4) bolts worked out on it. 1/4" bolts if I remember right. At that time there was no internet for help, no 4spd u joints to be found. So what I did was get one from a 3/4 ton truck that had a ball. Took it and the rear part of the 1/2 ton u-joint to a local machine shop. They turned out the original splined part on the rear of the 3/4 ton joint and welded and machined the splined portion from my 1/2 ton 4 spd joint. Works great, only thing is you need to pull the rear end back to separate the assembly now...... John | | |
