Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Sedgewick, Charles in CA, crenwelge, UtahYork, TexasFarmTruck, Mike1933), 161 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#929026 03/20/2013 2:48 PM
So I've called around looking for a u-joint repair kit for my 52' half ton and nobody has them in stock. Everyone says their on back order. Anyone know where I can find one?
ODSS Lawman
ODSS Lawman
Have you tried your FLAPS? You will be surprised what you can find there.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Unfortunately my local "FLAPS" are all big chain stores that say their computers don't go back that far. I'm gonna stop by a transmission/drive shaft shop and see if they can fix my u joint.
ODSS Lawman
ODSS Lawman
If I am looking for a part, I first check local FLAPS websites. In my area Advance Auto and Autozone are the most popular followed by NAPA. I go on their websites and look myself then arrive at the store with a part number. Takes all the frustration out dealing with the rookie behind the counter.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
3-speed or 4-speed (important differences, if you need yokes)?
What parts are you looking for?
u-joint-cross & "caps"/bushings?
Go to a NAPA and tell them to pull a book off the shelf.
I was suprized at one of my local napa's it was a younger fella that knew the older stuff pretty good.
Finally found a supplier on ebay that had U joints in stock! Had to cancel my order today (ordered a month ago) from classicparts.com. Hopefully the manufacturer will get rolling again and get these u joints out to the big parts suppliers. I might order a second one just to have a back up in case something like this happens again in the future.
A note on compatibility. I have found that my 54 chevy pickup and 54 chevy sedan use the same u-joint and u-joint yoke that slides onto the drive shaft.
Walt Williams
La Verkin, UT
Walt,
Does your '54 sedan have a Powerglide transmission?
Does you '54 truck have a Hydra-Matic transmission?
oldchevytrucks has not told us what transmission he has (or, u-joint parts he needs).
TC,
The U-joint repair kit you posted earlier (http://www.classicparts.com/1940-54-U-Joint-Repair-Kit-1_2-Ton/productinfo/92-215/#.UVH82RyG30d ) from classicparts.com was the very kit I had ordered a month ago. My truck has a 3 speed on the column.
oldchevy trucks,
Sorry to hear about that. That kit is the easiest to find set of parts for a u-joint (Jim Carter and Chevs of the 40s, and I suppose other vendors have that kit). Some of the splined yokes are often harder to find.
Too bad no one posted a NAPA part number, so you could have gotten them locally. I could not find a set by searching NAPA.
I contacted every vender I could find including Jim Carters and Chevsofthe40s. I was surprised that not a single vender had the part. This is the first time I had this problem not being able to find a vender that actually had the part in stock. Almost everyone sells it, but nobody has it. The company on ebay I ordered from already has it shipped and on the way.
good perseverance, oldchevytrucks
My experience with u-joints for the older stuff has been that the local store probably has them, but often you need to do one of two things:
- If it is a relatively young person, make him take them off the
shelf and match yours OR, if you get permission, do it yourself
- Find an experienced (not necessarily old) person, they often can
recite the part number from memory
It's as Tim said, good perseverance.
don
My sedan has a powerglide. My 3100 pickup has a 4 speed.
Walt Williams
La Verkin, UT
My 1/2 ton 53 Chevy had a 4 speed transmission in it. The u-joint (4) bolts worked out on it. 1/4" bolts if I remember right. At that time there was no internet for help, no 4spd u joints to be found. So what I did was get one from a 3/4 ton truck that had a ball. Took it and the rear part of the 1/2 ton u-joint to a local machine shop. They turned out the original splined part on the rear of the 3/4 ton joint and welded and machined the splined portion from my 1/2 ton 4 spd joint. Works great, only thing is you need to pull the rear end back to separate the assembly now......
