4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#930376 03/25/2013 11:26 AM
I am looking at purchasing some late model seats for my 52. I know they will fit and bolt in question is passenger is manual and driver is power seat. is it as easy as providing a power source to the seats for them to work?
Paul
wodniw5 #930452 03/25/2013 4:18 PM
If you have 12 volts and access to the junction block or battery, it should be easy. If the wiring is in rough shape consider providing a new wire to the batery with a fuse/switch in between.
wodniw5 #930750 03/26/2013 5:43 PM
I ran a wire from the fuse block under the floor mat/jute and ground wire between the seat frame and the seat riser. It stays hot all the time which is what I wanted. It works great.
