4 members (52Carl, Gdads51, JW51, Bisbee), 40 guests, and 3 robots.
Topics128,062
Posts1,055,845
Members48,428
i have the original boot was wondering if someone knew if it could be duplicated by a company
Riding in the Passing Lane
LMC has them.
1972 Chevy c10 Cheyenne Super
Neither the factory-correct t-case shifter boot, nor the factory-correct 4-speed floor shifter boot, for the '60-'66 Chevy/GMC trucks, Panels or Suburbans, are being reproduced, with any semblence of quality, fit & finish, as comparted to the original boots. We use the following from Classic Parts for the 4-speed and t-case shifter boots on our '60-'66 Chevy 4x4 trucks & Suburbans:
Floor shift boot - 40-626 (68-72) - 4wd - $19.95
Transfer case boot - 40-641 (71-72) - $19.95
We have found these to be the closest match. We have a factory-correct, orginal, t-case shifter boot, we are attempting to have reproduced, at this time.
i well aware that they are not being reproduced and the 1 you are talking about repo is junk at best and no where close to the original thats why iasked if anyone knew who could make 1 like the original 1
i have several nos 4 speed shift boots, just need the transfercase boot
No doubt about the quality, fit & finish. We have used them, when they were the only option, over a few holes in the floor. We haven't found a manufacturer yet, but we are working on it. We have several '60-'66 Chevy trucks, in the que, and will be needing the 4-speed shifter boot & t-case shifter boot, again soon. I will let you know if we secure a service-provider.
I would like to see a photo of your OEM/NOS t-case & tranny shifter boots, if you have any. Thanks.
Tony - if you can supply good originals to copy, Steele Rubber will repro them for you and add them to their catalog .... I found some NOS [early take-off] TF panel barn doors with factory rubber still on in decent shape and they did an excellent job of reproducing it quickly, including the metal clips for the corners
Iwill call steele rubber
We have reached out to Steele Rubber on a few occasions, only to discover, they are six months out, or more, looking at the part and providing production costs. After an 8 month wait, I was told they weren't able to produce an item for us, that was specific to the '60-'66 Chevy Suburbans & Panels. I told them, thanks for trying and they sent the original items back to me. Not a pleasant experience, but thanks for the suggestion.
