1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
#930322 03/25/2013 6:31 AM
Hey All,
Tinkering on my 1955 3100 2nd series and need to know the correct location of the radio antenna. Was it in the passenger side cowl below the windshield or the passeger side fender. I have holes in each and need to patch one of them! I am thinking the cowl is correct but want to be positive!
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
the fender is where it's located, a template was provided with the radio, guess yours got lost grin
Be careful drilling, measure and check underneath.....several times. The antenna I got From fleabay had a template that looked like a photocopy. AFTER drilling I found the hole was behind the inner fender support not in front. Had it not been for some creativity and a Karmann Ghia antenna base I would have been in for some body and paint work. I ended up with a parts store top mount antenna with the Ghia angled chrome base. Looks fine but what a panic.
You need the accessories installation manual, I think it gives all the dimensions etc. It goes in the rh front fender and has bracketry that attaches to the plenum/cowl on that side. I'm going to try to figure out some other place for mine when I get one, or some other kind of antenna.
some other place for some other kind of antenna
If you are installing a OEM type antenna, The placement is Critical on the fender. There is a slot in the cab for it to slide between cab and fender.
