4 members (kbenz, cmayna, Cletus1950, 1955 1 Series), 94 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
I lost one of the 2 little screws that hold the gearshift upper support to the steering column just below the gearshift lever. Anybody got one? Can I get this in a hardware store? The one I still have seems kinda special looking. Thanks!
Jay - yes they're pretty odd, I've never seen an exact match at a hardware store, but some vendors have them - called shift knuckle screws
I have a four speed on the floor and I think I am having the same issue. The two pins that hold the gear shifter in place are worn and need to be replaced. Is this what you are referring to, the shift knuckle screws? The ones in there now are loose ans spin in the holes but wil not come out. Will these replacement knuckle screws fix my problem? Thanks in advance.
no kbr, the screws referred to hold the 3 speed shift lever on the steering column, nothing to do with the SM420 4 speed, but you might find something here
For the SM420 I would contact someone at that Novak link Bill put up and see what they recomend. The only choices I can see to fix the loose pins, is #1 Pins with an oversized end that contacts the cast iron hole, and normal size for the shift lever retainer. #2 ream the holes larger and install bushings for the pins. #3 weld and redrill the holes. #4 Epoxy ie JB weld the pins in the holes. #5 If they aren't too loose use locktite retaining compound.
Jay
I may have those on my old column. Planning to reuse the column but not the shifter. I will dig it out and look if you are interested. You can have them if I can find them
R-Bo
1966 GMC 305V6 in the family
The 4 speed posts should be moved to a separate thread...
R-Bo!! Yes, I am very interested.
Red58. Thank you for the link. If I can't find the real deal, I will order those.
