2 members (3B, 1955 1 Series),
36
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | want to hook up horn for my 48 gmc, have horn nothing else, what else do I need | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wire would help  usually you need a horn relay to activate the circuit while keeping the current away from the horn button, which just supplies the ground to activate the relay and pass the current to the horn .... a factory diagram would be good, one from a Chevy manual should work if you remember to change polarities shown, providing you're running positive ground Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Brad - I don't believe GM ever put the hot wire into the column, if that wire out the bottom of the column goes to battery + there would be a dead short when you pushed the horn button - the column wire supplies ground to the relay to activate it, the ground on the horn is to complete the circuit when the relay supplies power, and most years the horn ground is supplied by the case mounting
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Two wires I will leave the rest to you electricians. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There was no horn relay supplied with a standard, single-horn Advance-Design truck until 1953. Prior to 1953, a horn relay was supplied with the accessory dual horn kit. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, if the 48 GMC didn't use a horn relay, and you don't want to add one, than the horn mount was isolated from ground, the hot wire went direct to the horn, and the horn button wire supplied the ground to a 2nd terminal on the horn .... as I said, a wiring diagram lays it all out Bill | | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | I will go by the wiring diagram, thanks for info guys... | | |
