8 members (Wayne67vert, TUTS 59, Hotrod Lincoln, Otto Skorzeny, klhansen, Shaffer's1950, Dragracefan, fonz8261),
172
Mod | | | Forums66 Topics128,165 Posts1,056,992 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am curious on whether NOS or old never used refurbished brake shoes are a good thing. I am thinking about the bonding and what age might do. Any opinions ? | | |
#9299 08/24/2003 12:04 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I suppose rivited linings would be better? I'm thinking the lining material may change over time,maybe. | | | | | Joined: Jun 2000 Posts: 30 Member | | Member Joined: Jun 2000 Posts: 30 | not an expert here but.. Chances are the nos shoe would have the asbetos included which will degrade over time. (re:lawsuits) Althoe it may not be visible, there could be significant deterioration. This may be taking "restoration" a bit too far. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | rodS, that is very interesting. Are you saying that the older asbestos types had some failure problems? | | | | | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | NOS brake shoes certainly contain some asbestos, but I don't think that's a reason not to use them. Just wear a mask when you remove them, as the dust will have some asbestos.
As far as durability, hard to say. I'd be more inclined to run a softer 'organic' shoe, so as not to wear the drum as much. Old drums are not getting more common, and once they're worn too far.....
Metallics and old asbestos are generally more abrasive than newer materials.
But I'm sure the old shoes would work well enough.
Cheers! George | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | George, I hear ya. I thanked my lucky stars when my drums cleaned up OK. They just don't make the 1 Ton drums for these old ones any more. | | |
