| | | Forums66 Topics128,260 Posts1,058,288 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | If your running a pcv valve on a small block chevy, do you still need a breather? Also, if you are running a pcv, is it a problem to also be running a breather? Thank you for your help | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy SD66Burb, the short answer is yes. Whatever your engines displacement, what is displaced above the pistons also is displaced below the pistons. We don't want the crankcase to be a negative pressure area or a positive pressure area, we want the air to be able to circulate freely, hope that helps. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what BBB says, if you're asking about the vented oil fill cap - if you're referring to the road draft tube, it should be gone
Bill | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Yes, that is exactly what I was looking at. I am putting in a 350 crate engine,from my 283, so I will be running a PCV from the carb to the valve cover, but I still was going to run the oil fill tube in the intake with the breather cap, to try and look a little period correct. The road draft tube is going in the trash. Thank you for your help. | | |
