5 members (artinva, Opelika Tom, JW51, Gdads51, Otto Skorzeny), 65 guests, and 2 robots.
Topics128,077
Posts1,055,932
Members48,430
#929537 03/22/2013 7:51 AM
If your running a pcv valve on a small block chevy, do you still need a breather? Also, if you are running a pcv, is it a problem to also be running a breather?
Thank you for your help
3B Offline
Hy SD66Burb, the short answer is yes. Whatever your engines displacement, what is displaced above the pistons also is displaced below the pistons. We don't want the crankcase to be a negative pressure area or a positive pressure area, we want the air to be able to circulate freely, hope that helps.
what BBB says, if you're asking about the vented oil fill cap - if you're referring to the road draft tube, it should be gone
Yes, that is exactly what I was looking at. I am putting in a 350 crate engine,from my 283, so I will be running a PCV from the carb to the valve cover, but I still was going to run the oil fill tube in the intake with the breather cap, to try and look a little period correct. The road draft tube is going in the trash.
Thank you for your help.
