| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | For 49-3100. Is there a adjustment nut on the starter foot pedal or linkage so the linkage pushes the starter button further in? Any photos or diagrams would be great. Thanks | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | if its the same as a 55 stomp start pedal it just is screwed on and you adjust it by tightening it or loosening it Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you're meaning the button on top of the starter isn't making electrical contact, that's a problem inside the box under the button, not with the linkage to it, unless there's extreme wear on the [non-adjustable] linkage
Bill | | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | I can push the button on top of the starter and the truck will start. When I use the foot pedal the linkage does not depress the button far enough. Since the linkage is non-adjustable looks like the only fix is to make a longer rod to depress the button more. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | be better to figure out just what's happening, the factory pieces should work without modification - you likely have wear on the face of the pivoting piece that hits the button, as well as wear of the big copper chunk inside the switch - might fix it by a spot of weld on that lever piece or turning the copper piece over, possibly by just dressing that copper piece back to shape, they tend to get dirty and eroded from arcing
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill is still correct. The copper-button on top of the starter or contact-button inside the starter switch is worn. I have temporarily and safely gotten by the situation by taking a small length of water hose and slitting it open. Then, place the piece of hose over the button on the top of the starter switch (keep a spare piece of slitted hose, in case the piece on the starter switch falls off). This is called a jack-legged (jerry-rigged, jury-rigged, shade-tree, half-aXXed) repair. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I have a nut on the starter button shaft (cab side) that I use to tighten the shaft after it's threaded into the linkage stub. My starter button shaft doesn't protrude thru the linkage stub on the engine side. If the end of your starter button shaft is hitting the bellhousing prior to the starter switch being fully pushed down use of a nut like I have may help.
Ed
| | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | I should have mentioned in my original post that my starter and starter switch are brand new. I'll look at the starter button in the morning. Can I get to the jamb nut on the starter button from inside the truck thru the floor or is it all from under the truck? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Insider or outside if you depress it. The button threads on to the shaft and the jamb nut is part of that shaft. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the jam nut is to keep the pedal from coming loose, I doubt you can gain any increased pivoting by fiddling it .... if you've changed the switch box on the starter, maybe you need to build up the button, sort of like Tim suggested above, but more permanently
Bill | | | | | Joined: Mar 2011 Posts: 1 Moderated | | Moderated Joined: Mar 2011 Posts: 1 | From experience with the exact same problem I removed the rubber cover of the foot feed then ground off the end of the hinge pin, removed the pedal and silver soldered a thick piece of flat metal to the underside of the pedal being careful to leave just a tiny bit of clearance between the pedal and the starter button then finished up by finding a bolt to the same size as the hinge pin and re-assembling the foot feed. Worked for me from Jr, thru Senior high school years. | | |
