4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#929413 03/21/2013 5:25 PM
my ID plate is covered in paint at the very top is HGJ stamped in then lower is C 51 385 then lower is the VIN 6VWC 1601 break down is yr 1952 mod 6400 2ton wb 161" I did a search but no luck ohwell on code thanks for your help
might be different on the big bolts, but paint and trim codes are on a separate tag from the vin on pickups
You will not find a paint code on any data plate in 52. They did not exist. I do not know when they started putting paint codes on the trucks but it was at the very least, after 54. On my truck, written in grease pencil on the underside of the hood, is written "Transport" for transport blue. You may get lucky and find something like that but that is the best you can hope for other than finding some original paint in a hidden area of your truck.
If you are referring to a 1952 USA Chevrolet truck (which the year of the 6VWC 1601 Vehicle Number), there was no paint and/or trim code placed anywhere on a tag on the truck that year. Does not matter what size truck you have.
6VWC 1601
6 = Oakland
VW = 1952 6400 series
C = March
1601 = 601th 6400 series truck produced at that plant that year (1601-1000)
If you are referring to the Vehicle Serial Number plate (upper right on this page), 6VWC 1601 was the only code originally put on that tag. The other code might be an attempt to put an engine code on that tag (for a replacement engine?).
Can you post a photo of your tag? Or, mail a photo to me and I will post it here lederman@siena.edu.
It's not unusual to find the paint name written on the underside of the hood on '55 and earlier trucks.
Bill Burmeister
Thanks for the reply's so quick Tim I will try to post the tag this weekend
Thanks again
Jay`
jay where in pa are you located?
My plate photo bucket
and some of my truck
51 ashton I am 7 miles west of york in Dover
