7 members (50Chevy3100, RdsLessTaken, DadsFirstPickup, tclederman, Cletus1950, Ponchogl, 1 invisible),
202
Mod | | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | I can't find this part referenced in any parts manual parts catalog or the factory or service manuals. There appears to be an orafice on the hollow bolt that goes through the brass block that shoukld line up with the side outlet. The hollow bolt will not come out of the block. It rotates freely and comes out a little ways then stopps like it was meant to stop. I hope the pictures help. does anyone have experience with this piece? it's on the master cyclinder of a 53 3/4 ton. http://s1192.photobucket.com/user/rgies/library/53%203%20quarter%20ton%20master%20cylinder thanks rolf
1963 c10 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rgie, that is a banjo fitting and bolt, the bolt should come out of the fitting. If the seat in the fitting is okay there is no reason not to re-use it, use two new copper washers of the correct size when you re-assemble it for use, hope that helps. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | 3B I tapped on the bolt with a rubber mallet. I will re-use it. Do i need to line up the small hole in the bolt with the side outlet port? I can't tell if there is a groove around the bolt that would let the fluid exit the side port. I will attempt to get the bolt out again, it would be a shame to mess it up since it's in good shape.
thanks again rolf
1963 c10 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rgie, there is no need to turn the bolt to a specific direction, as you suspected there is a groove all the way around the bolt to allow the fluid to move in any direction, hope that helps. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | 3b thanks got everything put back together and bled the brakes, even got the cab set today!
thanks again rolf
1963 c10 | | |
