1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#928727 03/19/2013 2:52 PM
Dose anyone have pics of the rear motor mounts that are on the bell housing.Its been to long and I can't remember what they bolt to.I want to get the engine back in the frame by this weekend.
year/make/model/engine
Quote
ohwell
You did not say what the application is for.
If it is the 46 in you photo album then you need 2 ANR 2060 for the rear and 1 ANR 2007 for the front. Both are available from your local Auto Parts Store. You can just Google Anchor - Transmission Mount #2060 and you will see photo's of the mounts
Good luck with your rebuild.
Harold
yahoo
Harold
Harold46 #928773 03/19/2013 6:03 PM
sorry it is for a 46 chevy truck.I have a mount ordered and have the old mounts that bolt to bell housing,but I don't remember how or what the other end bolts to on the frame.Maybe it will make since when I get the engine in the frame.Any and all help is welcome.Does the shop manual show pics of things,if so maybe I need to order 1.
The front mount is a flat rubber mount with a oil shield over it. You can see this on Pg5 of my photos. The rear mounts ar U shaped and attach to the bell housing. And the transmission mount can be seen on pg 3 of my photos.
Thanks,I didn't realize the rear mounts sit on the cross member.The color of your truck is very close to the color I picked out for my truck.The color I picked out is ppg Big league blue.Your pics will be a big help.Thanks again.
[IMG]http://i629.photobucket.com/albums/uu14/kurtdh519/4-12-12014.jpg[/IMG]
this is a picture of my 46 1/2 ton rear motor mounts
Your truck looks good. I am using Omni Urethane Paint. Its "Safety Blue" with 1/2 the white removed. I was trying to get to Export Blue. i see your not a fan of chevys pink interior either!
Thanks for the pic Hoozat.These pics help a lot,but I am still a little unsure if the mounts fasten to the frame or just sit on the frame.If they fasten to some kind of bracket ,then I don't have it.I have new mounts on the way as the rubber is gone on my old ones and I just have the metal part on the bell housing.I am also missing some kind of bracket for the peddles.My peddles are mounted on a bracket withe master cylinder,but it looks Like I need another bracket to fasten it to what ever it bolts to.maybe the 3 bolts in the back of the bell housing? GWWirth I am also using singal stage urethane,But the fenders and running boards will be a darker blue metallic ;so I plan on using 2 stage urethane ( base coat clear coat)
Ok, after looking your pics and I went to the garage and looked at my peddles ,I have what I need to mount them. Thanks again.
Metal Shaper,
I guess you did not read all of my post above so am resending the part about seeing the mounts.
Harold
Harold
Harold, thanks for the info .I did do the google search, and only saw a pic of the mount.I didn't find a pic with it fastened to the frame.But your information of the part numbers helped me understand that I can get a lot of parts local and not have to pay higher prices at a restoration supplier. I did not know the parts stores went back that far. Thanks again for your help.
