| | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Dose anyone have pics of the rear motor mounts that are on the bell housing.Its been to long and I can't remember what they bolt to.I want to get the engine back in the frame by this weekend. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Dose anyone have pics of the rear motor mounts that are on the bell housing You did not say what the application is for. If it is the 46 in you photo album then you need 2 ANR 2060 for the rear and 1 ANR 2007 for the front. Both are available from your local Auto Parts Store. You can just Google Anchor - Transmission Mount #2060 and you will see photo's of the mounts Good luck with your rebuild. Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | sorry it is for a 46 chevy truck.I have a mount ordered and have the old mounts that bolt to bell housing,but I don't remember how or what the other end bolts to on the frame.Maybe it will make since when I get the engine in the frame.Any and all help is welcome.Does the shop manual show pics of things,if so maybe I need to order 1. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | The front mount is a flat rubber mount with a oil shield over it. You can see this on Pg5 of my photos. The rear mounts ar U shaped and attach to the bell housing. And the transmission mount can be seen on pg 3 of my photos. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Thanks,I didn't realize the rear mounts sit on the cross member.The color of your truck is very close to the color I picked out for my truck.The color I picked out is ppg Big league blue.Your pics will be a big help.Thanks again. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Your truck looks good. I am using Omni Urethane Paint. Its "Safety Blue" with 1/2 the white removed. I was trying to get to Export Blue. i see your not a fan of chevys pink interior either! | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Thanks for the pic Hoozat.These pics help a lot,but I am still a little unsure if the mounts fasten to the frame or just sit on the frame.If they fasten to some kind of bracket ,then I don't have it.I have new mounts on the way as the rubber is gone on my old ones and I just have the metal part on the bell housing.I am also missing some kind of bracket for the peddles.My peddles are mounted on a bracket withe master cylinder,but it looks Like I need another bracket to fasten it to what ever it bolts to.maybe the 3 bolts in the back of the bell housing? GWWirth I am also using singal stage urethane,But the fenders and running boards will be a darker blue metallic ;so I plan on using 2 stage urethane ( base coat clear coat) | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Ok, after looking your pics and I went to the garage and looked at my peddles ,I have what I need to mount them. Thanks again. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Metal Shaper, I guess you did not read all of my post above so am resending the part about seeing the mounts.
You can just Google Anchor - Transmission Mount #2060 and you will see photo's of the mounts Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Harold, thanks for the info .I did do the google search, and only saw a pic of the mount.I didn't find a pic with it fastened to the frame.But your information of the part numbers helped me understand that I can get a lot of parts local and not have to pay higher prices at a restoration supplier. I did not know the parts stores went back that far. Thanks again for your help. | | |
