| | | Forums66 Topics128,086 Posts1,056,099 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | So my new cab is coming in two weeks.... This is a good thing since my friend already did some structural testing on my old cab. In case anyone is wondering a severely rusted 1954 AD cab will hold one round hay bale on top of it.... but not two. Ask me how I know... lol.
Anyway- the cab and front end I have coming is off of a big bolt so the fenders/front end are of the bigger variety while the 3800 originally came with the smaller fenders.
i sort of like the big bolt look with different proportion of big front end to cab and the fenders are in much better condition than mine. i can save my fenders but it would be more work for sure. they are pretty strait with no bondo but need the mounting flanges repaired. i would also have to buy a new grill which could be costly if i keep the original 3800 small grill look.
So are the 1-ton trucks "rare" enough that I should keep it original or should I fab up some frame extensions at which point I would have the same frame as a 1-1/2 ton and with my new body could make a 4100 "clone?" I love the look of both trucks but i think i lean toward the 4100 slightly. This will be a steak body dump when I'm finished.
opinions? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you don't have the pickup bed then why not make it more like a 4100 with the good sheet metal? However if you use the big fenders I'd be sure to use some tires that do a decent job filling them.
A 1 ton flat bed isn't that rare or desirable simply for what it is so might as well make out of it what you please.
Grigg
| | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Thats what I'm thinking...
If I had the bed I'd probably stick original but this truck had a hoist on it already which I plan to repair and make into a steak body dump (with a gooseneck hitch if I can squeeze it in.
The wheels I have on it are 18" vs. the 4100's 20" but I think the tire height is the same or very close around 33". So I think it will be OK as is but I could always change the wheels/tires.
At that point it would be pretty much the same besides springs and axles. Might have to replace my springs but I dont think it's worth beefing them up for how I'll be using it... As it is I think the p/o already added some leafs in the back. At some point I have to find out what stock ride/frame height should be.
Tj | | |
