0 members (),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92850 09/02/2005 12:09 PM | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Okay guys this is probably a couple of really dumb questions but I'm stumped so will ask anyway. On my 57 GMC when I turn on the lights the interior dome light comes on. There are no door switches or other switches to turn it off. I have tried rotating the headlight switch and that doesn't work. Is this thing wired wrong or how in the heck do you turn the #@!&% thing off? Second dumb question. I am trying to hook up the radio (factory NOS). There is 1 speaker wire coming from the radio and my after market speaker has 2 terminals, + and -. If the + side goes to the radio connection does the - side go to ground? If these questions give you a laugh then I made your day, if you can help me it will make my day. Thanks, Don | | |
#92851 09/02/2005 2:29 PM | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | GMC, I can not help with the dome light, but if you want the quick fix, just add a switch to the light circut.
On the radio, the output from the radio goes to the + side of the speaker. The - speaker lug goes to ground. | | |
#92852 09/02/2005 2:40 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds like you hooked the dome wire to the wrong terminal, tho a bad headlight switch might do that
Bill | | |
#92853 09/02/2005 2:53 PM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | For a quick solution to the dome light until you can figure it out just remove the bulb.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
#92854 09/03/2005 12:42 AM | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | I received my shop manual today and checked out the section on lights. The dome light should turn off by rotating the headlight switch knob. It doesn't do that so I guess my switch is bad. Thanks for the replies, Don | | |
#92855 09/13/2005 1:12 AM | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Check to see if the terminal you have the light hooked to is hot all the time. On my switch the dome light has power all the time and a counter-clockwise turn of the knob to the stop makes the ground connection for the light, which is on a terminal at the front of the switch next to the guage light rheostat. I have read that the switch should turn off the power and the other side of light is just grounded. I dont know for sure which way is correct but mine works as I described. Good luck Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#92856 09/13/2005 2:42 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know what kind of speaker you have there but + and - have no meaning for a speaker. Most old auto radios have one wire active to the speaker and the other wire is ground. However, some speakers are internally grounded on one lead so it makes them polarity sensitive. I recently ran in to this with a new replacement from Jim Carter. | | |
#92857 09/13/2005 5:32 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Speakers are also marked + and - to keep the phasing correct in multiple speaker installations. Probably not an issue in this case.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#92858 09/14/2005 12:24 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I agree w/ Red58 the dome light wire may be connected to the lights post or you have a faulty switch. try tracing the dome wire and see what it's connected to. It may also just have come in contact w/ the lights post and is wired correctly. In that case simply move the terminals apart and insulate if necessary. the neg. speaker post should go to ground so just connect a short wire to the new mounting bolt (or any frame bolt) of the speaker.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#92859 09/14/2005 2:16 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | Hooking the speaker (-) will work fine.
On the dome lamp - check to see if you have a bulb with only one filament (only 1 bump on the base) where you actually need a two filament bulb. I had some funny back-feed when I did this, symptoms were similar. | | |
