0 members (), 163 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#928183 03/17/2013 11:08 AM
At last report I'd had the system flushed. Then idled for 30 min and laser gun said 174 on the block. I called The Filling Station yesterday and was told by tech to idle with cap off to bleed air out... Did that and yes, small bubbles started coming up..then looked like steam but no hard boil. Water temp at the end was 185. Gauge is a 49..not a 56 so it's likely toast and needs to be replaced. I still dunno if I'm overheating or not...didn't like seeing steam coming off the water. Also not sure if gas gauge is right and ammeter is off too. Maybe need to replace the whole cluster... ?
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Dogface #928194 03/17/2013 11:47 AM
Haven't you ever watched a tea kettle heat up? Or seen a bathroom faucet steam in a cool room?
Drill a 1/8" hole in a new thermostat and replace the radiator cap with a 160 and put it on and run it. Your worrying too much.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Dogface #928198 03/17/2013 11:57 AM
Put in a new 160 thermostat Friday...why the 1/8" hole ? Easy to buy a new cap.
Yes, I guess I do worry cuz I don't wanna fry the engine. Admittedly, I'm new at all this...so thanks for the help... smile
Mark
1949 Chevy 1/2-Ton
Lucielle
Dogface #928202 03/17/2013 12:11 PM
The holes to let trapped air purge. ...pic...
The last stat I purchased had a little check valve buit into the flange to do the same thing.
I don't know what kind of rad cap you are getting but I would suggest not going over 7 lbs. A 4 lb cap would be good.
1951 1 Ton Completed
