8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92811 08/28/2005 11:16 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Here is the new wiring diagram I made up for my '48. 48 wiring I am running a one wire alternator and HEI setup so there is no regulator or coil shown. Just thought I'd share it with the rest of you. | | |
#92812 08/28/2005 11:35 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Nice work Inky. What did you use to create the diagram?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#92813 08/28/2005 11:43 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | I drew it in AutoCad and converted it to both JPG and PNG formats so I could post it. I posted the PNG because it is a little better quality. | | |
#92814 11/10/2005 8:51 PM | Joined: Sep 2005 Posts: 23 Junior Member | | Junior Member Joined: Sep 2005 Posts: 23 | Thanks for the diagram! Where did you get the HEI distributer? Did that help the truck run over 45mph
You thought I drove a Ford! Where is my cresent wrench, I would like to adjust your thought pattern.
#92815 11/10/2005 10:23 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | HEI from 82 chevy 250. Not for increase in speed... just reliability. | | |
#92816 11/17/2005 12:29 AM | Joined: Nov 2005 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 66 | Excuse my ignorance. What is an HEI. I just bought a 1953 Chevy 3100 with a 235 inline that came out of a 1958. I'm just curious though there is soooo much I need to do before I even get to the wiring. | | |
#92817 11/17/2005 1:13 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mario23,
HEI is an acronym for High Energy Ignition. It is a solid state, or breakerless distributor.
Stuart | | |
#92818 11/17/2005 2:15 AM | Joined: Nov 2005 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 66 | Ok thanks. So what I have to figure out is if I already have this thing already under my hood being that its a 58 235 engine... I'm learning. Believe me, I've learned alot in the past few days with much more to go... | | |
#92819 11/18/2005 10:11 PM | Joined: Sep 2005 Posts: 23 Junior Member | | Junior Member Joined: Sep 2005 Posts: 23 | OK Ink05, I ran wires from the two tail lights up to the cab. One side went to the Brake sw and the other went to the fuze box to the tail light fuze. When I bulled the lights on the running lights worked, but I could not get the brake lights to work. I had power up to the NEW BRAKE switch but when I had the pedel pushed down the switch would not make the connection to the other wire. I purchased a New brake sw to avoid this problem:( I did use the old connector to attach the new wire to the sw. I am using a light prob to check for power.
What Now??? I do have power to one side of the Brake sw but I am not having any luck wiht the brake sw. Oh ya, Now my dam truck wont start. I put the battery charger on it for a few days to make sure I have a good charge.
#92820 11/19/2005 12:19 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mario23,
A GM HEI cap is just a little smaller than the Hindenburg...easy to identify.
N D Loadmaster,
Use your probe and work backwards from the SUPPLY side of the brake switch, you said you know you have power there, check it again. Then probe the other side of the switch..manipulate the switch until you get power there. Go to the back of the truck and poke the wire with the probe..it should be hot. You should be able to get to the tail light and still have power.
If you have power all the way to the socket, and still no brake light...check, replace or wiggle the bulb. That lamp is the stop/tail combo so it goes in only one way. If this is all perfect, and still no light, you need to investigate the ground. Nothing works without a ground.
Using the probe, start at the known source of power and work toward the problem. You will come to a point in system where power is no longer present....you found the problem! Have your wife, girlfriend, neighbor or child help you. They can push a brake pedal or watch a light.
Don't think because the brake switch is NEW that it works...PROVE it works with a meter or your probe. Your brake arm must go down far enough to make the brake switch close.
Stuart | | |
