1 members (NJC),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92798 08/28/2005 10:28 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm tired of maintaining six volt batteries to run a truck I only start once or twice a year. So I decided to convert my '52 6400 to 12 volts.
I bought a 12-volt coil and an ignition resistor and started wiring. Suddenly I realized that with a foot starter there is no readily available electrical connection that bypasses the ignition resistor when you press the foot start.
Anyone found a slick solution for this problem? What have others done?
The cleanest solution that has come to my mind so far is converting to an HEI, but that defeats the less trouble purpose I started with....
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#92799 08/29/2005 12:12 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | A foot start mechanism from a second series up should have the coil terminal. | | |
#92800 08/29/2005 1:28 AM | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | How about a monentary contact push button under the dash you can press and hold while starting?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
#92801 08/29/2005 2:10 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Baldy: A foot start mechanism from a second series up should have the coil terminal. I didn't know those existed. Thanks for the tip, I'll look for one of those!
#92802 08/29/2005 2:22 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Gord&Fran: How about a monentary contact push button under the dash you can press and hold while starting? That would work but its the kind of solution I want to avoid... I'd almost rather use some kind of current surge measurement to trigger a relay than push another button. Maybe I should give up and put a selenoid starter in instead.
#92803 08/29/2005 2:43 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I have what baldy described. Works great. It's the contact that bolts to the starter. It has an extra terminal on it just for this. Check out Chevy Duty Part # 53-712 Switch pic | | |
#92804 08/29/2005 9:52 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you use the stock 2/0 6V battery cables on your 12v conversion you don't need that bypass contact. My truck cranks and starts just fine in 10 degree weather without it.
#92805 08/29/2005 11:00 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by 4ontheFloor: If you use the stock 2/0 6V battery cables on your 12v conversion you don't need that bypass contact. My truck cranks and starts just fine in 10 degree weather without it. Hadn't thought of that... But the fact that those cables are already long gone is one of the reasons I was tired of fighting the six-volt battle. I bet it works just fine.
#92806 08/30/2005 12:12 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | I just used the 6 volt coil with the resistor feeding the coil...????? 6v to the coil all the time...??? why not do that..???
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#92807 08/30/2005 12:48 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Using the six volt coil is not longer an option because one of the posts broke off when I tried to remove the wire.
It was actually that event, which occured while I was troubleshooting, the moved this conversion from a thought to a sure thing.
#92808 09/09/2005 4:40 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | You will not need the by-pass if you use the fat battery cables as described above. Also to simplify things a lot go to NAPA and get an IC64 Ignition coil with the built-in resistor. A lot less headaches and a lot more reliblity.....Randy | | |
#92809 09/13/2005 6:11 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | get cables for a tractor there heavy and cheape i just got a 12 voit coil and a resister mine starts fine | | |
#92810 09/13/2005 10:56 PM | Joined: Aug 2005 Posts: 39 New Guy | | New Guy Joined: Aug 2005 Posts: 39 | Buy a switch similar to your brake light switch, mount it in such a way that your foot start mechanism operates it, and use it to short out the resistor.
Johannes
Simplicity leads to reliability.
