5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
I've got the chance to buy a set of new 2013 Silvarado take off alloy wheels and tires that I plan to put on my '94 C2500. Can anyone tell me if the stock 8 lug steel 16's will fit on my 55.2 3600?
They will physically bolt up fine, you might need a spacer on the front to clear the tie rodes, as the backspace is a bit deeper on the GMT400 trucks from what was on the '55s. However, there is a different issue you need to know about, the wheels from the '13 truck will not fit on you '94, the backspace is far too deep. If you hade a 4x4, it would work, but not on a 2wd.
Bill Burmeister
Dang, too.late. I thought about them not fitting the '94 but the deal was too good to pass up. Guess I'll put them back up for sale and give someone with a late model truck a chance at a great deal.
I hate to argue with anyone, but almost ANY factory wheel AFTER 1998 will NOT fit our older trucks, period. The newer wheels are 8 on 170mm, while we need 8 on 160mm or 8 on 6 1/2. Don't waste your time and money on late model wheels.
best wishes,
Les
I found that out the hard way around 2000. For many years I didn't carry an extra spare for my trailers because I could use my spare from the pickup. It wasn't very long that I discovered that my 2000 GMC spare no longer fit 7k trailer axles. My cousin who is a gmc dealer told me they had gone to metric. I trade pickups every 3 years, but I think my 2000 still had regular hubcaps which covered the bolt patern. My 2012 has the plastic nut covers and it is real obvious that the bolt pattern is different.
Well, when you need tires for your 2012 and would like some nice alloys for it look me up. Seems that Ill have a beautiful set that I cant use.
best wishes,
Les
That's only on Ford pickup wheels. E series vans, GM trucks, and Dodge trucks are still 8x6.5. The main problem is the deeper backspace and higher offsets that the modern wheels use.
Bill Burmeister
Longbox is correct. The late model GM and Mopar trucks still use the 8x6.5 wheels as do the Ford Vans. The difference being the late models have more positive offset and are hub piloted vs. stud piloted. They also one piece, not having the welded/riveted outer ring and center flange design. A benefit to the one piece design, is the abilitly to run larger rotors and calipers.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
