2 members (Hotrod Lincoln, Woodcmiami), 72 guests, and 3 robots.
Topics128,029
Posts1,055,417
Members48,422
#92742 08/23/2005 3:20 AM
As I was removing the cables this morning on my '47, which still has the battery under the floor, I was wondering where I was going to come up with a 4 ft. long cable on such short notice, as I'm sure they're not the most plentiful item in town. Then it hit me. We have a farm equipment dealer about 5 miles from where I live, so I stopped there. Turns out, they had the cable in bulk, along with all the different ends, and were able to custom make exactly what I needed. And it cost less than $20!
They also had the heavy gauge cable, so later on, if I need cables for my 6 volt stuff, I can get those there as well.
Just thought I'd pass this info along, in case anyone else had this problem.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
#92743 08/23/2005 7:19 AM
Welding supply is another place. Just make sure the crimp they put is a GOOD crimp. Otherwise that's a source of resistance, heat and arch.
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
#92744 08/23/2005 3:28 PM
H Online: Content
Since current-carrying capacity depends on the number of strands of wire, as well as the diameter, the hundreds of fine strands in a piece of #1 gauge welder cable makes for excellent 6 volt battery cables. Just solder, or crimp the terminals firmly. I prefer soldered connections.
