2 members (Jon G, Otto Skorzeny), 203 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
I was wondering if there are repops of the 55-59 suburban tail light assemblies available,I can find the lenses all over the place but the actual assembly with the wires and the lamp socket has been a bit more of a hunt.Unless someone has a pair of burb tail lights languishing on a shelf!!
sadly no one has reproduced those light assemblies, and as the originals are pot metal, once they get fairly pitted, they're goners - you could try a post in the parts wanted, a pair might surface
I've seen them on eBay. The Tail Light King has had them also. They tend to be pricey. Since my burb body isn't even drilled for the lights (clam shell with center light only) I'm trying to see if there might be an amusing alternative. John
Moderated
Moderated
I was wondering if you ever found any tail lights for your vehicle. I am trying to do the same to my 55 (2nd) panel truck. Can't find them anywhere. Did you find any or an alternative?
