| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 42 | I was wondering if there are repops of the 55-59 suburban tail light assemblies available,I can find the lenses all over the place but the actual assembly with the wires and the lamp socket has been a bit more of a hunt.Unless someone has a pair of burb tail lights languishing on a shelf!!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sadly no one has reproduced those light assemblies, and as the originals are pot metal, once they get fairly pitted, they're goners - you could try a post in the parts wanted, a pair might surface
Bill | | | | | Joined: Aug 2011 Posts: 24 New Guy | | New Guy Joined: Aug 2011 Posts: 24 | I've seen them on eBay. The Tail Light King has had them also. They tend to be pricey. Since my burb body isn't even drilled for the lights (clam shell with center light only) I'm trying to see if there might be an amusing alternative. John | | | | | Joined: Mar 2015 Posts: 1 Moderated | | Moderated Joined: Mar 2015 Posts: 1 | I was wondering if you ever found any tail lights for your vehicle. I am trying to do the same to my 55 (2nd) panel truck. Can't find them anywhere. Did you find any or an alternative? | | |
