2 members (Rich'sToys, 1 invisible), 65 guests, and 7 robots.
Topics128,014
Posts1,055,324
Members48,419
#926738 03/11/2013 10:30 PM
1948 3100 I just installed my original steering column and bolted the gear to the frame. Where the column meets the dash there is about an inch and a quarter gap. Where the new firewall seal lines up it looks as if the column needs to angle up to close that gap. Should I just loosen the bolts that hold the gear to the frame, line up the column seal and dash bracket then shim the gear box to meet the frame. I should add this is not the original cab. "48" cab on a "52" frame.
If you never tell a lie, you never need to remember what you said.
Bart,
Do you have the 2 piece column clamp,upper and lower?
You need the upper between the column and the dash as part of the spacing.
Are you sure the cab and mounts are in the right position.
Different mount on the rear of the early cab.
steve sr.
I do have the two peice column clamp. The upper clamp is about 3/4" of an inch away from the dash. The rear cab mount is also different. The "48" cab had the center mount. I installed the two shackles as the "52" cab had, thought I had them set to the correct heigth. I had to drill holes in the floor of the cab to install them. The front cab mount did not change, I just installed a new rubber peice between the cab and the frame. I suppose the rear of the cab could be a little high causing the problem. I could not find a spec. on that spacing so I set the rear cab to just touch the rubber stoppers that were on the cab rear sides for the one center style cab mount, then removed the stops. I suppose I could let the rear of the cab down some which would help but would it hurt if I just tilted the column up to match. I suppose if the cab is not just right I will have a similar problem when the front clip goes back on, won't I.
Over the years Bart the body’s shift from abuse, accidents happen, floor boards rust out
and are replaced, etc. Also as you said you switched cabs and just like a Christmas
cookie, even though they were made with a cookie cutter, it don't mean each one is gonna
come out of the oven looking exactly the same.
First off you've got to make sure you've got good cab mounts. As I'm sure you're aware
of, the 1948 cab used a single center rear mount which was replace in '49 and there after
by the double shackle mount. If these were not properly located it could cause the cab to
be a little to high in the rear causing the gap you see. Also it's possible that the frame
could have been bent in an accident. Either way you can shim the box at the frame to
bring it into the correct alignment. If it’s low by an inch then a 1/32” shim should bring it
right up to snuff.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Sorry, looks like you've already answered your own question by
the time I had to post that. I was composing earlier this
morning and got interupted to take the mutt out for her
morning constitutional and set out the garbage.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny, Do you think the cab could be off enough to cause a problem with the front fender alignment that I would need to reset the cab. Maybe I need to move this to the paint and body forum, or just get startd on the front clip and see what happens.
Bart
Whats up with the cab placement/alignment?
Please let know.
steve sr.
Denny G
Sandwich, IL
