0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#926595 03/11/2013 3:52 PM
49-3100. Started truck and backed out of garage. When I tried to restart truck-nothing. When starter peddle is depressed-nothing. Battery appears OK because with key on headlights and radio lights work. Tapped the starter-nothing. Is there a fuse to this cicuit? If so where is it? Thanks for any help. Everything worked great before this.
dougs #926600 03/11/2013 4:17 PM
No fuse to the starter circuit. My truck usualy starts fine when I step on the starter pedal. Sometimes it doesn't do anything and I have to STOMP on the pedal a couple times. You may have to replace the switch located on top of the starter. Real easy to do and the switches are available from most parts venders. I got one from Napa.
dougs #926660 03/11/2013 7:07 PM
Bendix may be hung up in flywheel. Be sure you have voltage to the switch on the starter as well as a good grounds. If the switch looks good (easiest to take off and check) then I would pull the starter. When you say nothing I assume you mean the starter doesn't even spin.
Ed
dougs #927297 03/13/2013 8:33 PM
My switch went bad just that fast. Contact was burnt just enough that it would not send voltage any longer.
If you never tell a lie, you never need to remember what you said.
