| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | 49-3100. Started truck and backed out of garage. When I tried to restart truck-nothing. When starter peddle is depressed-nothing. Battery appears OK because with key on headlights and radio lights work. Tapped the starter-nothing. Is there a fuse to this cicuit? If so where is it? Thanks for any help. Everything worked great before this. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | No fuse to the starter circuit. My truck usualy starts fine when I step on the starter pedal. Sometimes it doesn't do anything and I have to STOMP on the pedal a couple times. You may have to replace the switch located on top of the starter. Real easy to do and the switches are available from most parts venders. I got one from Napa. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Bendix may be hung up in flywheel. Be sure you have voltage to the switch on the starter as well as a good grounds. If the switch looks good (easiest to take off and check) then I would pull the starter. When you say nothing I assume you mean the starter doesn't even spin.
Ed
| | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | My switch went bad just that fast. Contact was burnt just enough that it would not send voltage any longer.
If you never tell a lie, you never need to remember what you said.
