3 members (cmayna, tclederman, 1 invisible),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92658 08/16/2005 4:38 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | i have the kind of temp gauge that has a solid piece of copper wire running from the sensor in the manifold to the meter. i assume the copper wire transfers heat or something. the gauge won't move unless i tap the sensor, then it moves to register 180 when the engine is warm. the gauge is new, at least i just bought it a few months back at a large antique parts store. is there anything to fixing these things or do i have to buy another one? thanks
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#92659 08/16/2005 4:46 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 'solid copper wire' is a capillary tube - they don't work if kinked and need a good clean connection at the sender end - sounds like you may have a bad one though - try putting the sender in a pan of very hot water and see what it does
Bill | | |
#92660 08/16/2005 5:53 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | what is inside the sender red58? it works if i tap it with a screwdriver a little on the side.
#92661 08/16/2005 6:30 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | but does it work properly? not sure if it's a fluid of some kind, or just air that expands w/ temp changes - the internal size of that tube is super tiny - why it has to have good contact - no teflon tape or sealer
Bill | | |
