8 members (cmayna, Gray_Ghost, Donf, Otto Skorzeny, Gdads51, Jon G, Forty9, Shade Baby), 104 guests, and 0 robots.
Topics128,118
Posts1,056,307
Members48,439
i have the kind of temp gauge that has a solid piece of copper wire running from the sensor in the manifold to the meter. i assume the copper wire transfers heat or something. the gauge won't move unless i tap the sensor, then it moves to register 180 when the engine is warm. the gauge is new, at least i just bought it a few months back at a large antique parts store.
is there anything to fixing these things or do i have to buy another one?
thanks
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
the 'solid copper wire' is a capillary tube - they don't work if kinked and need a good clean connection at the sender end - sounds like you may have a bad one though - try putting the sender in a pan of very hot water and see what it does
what is inside the sender red58? it works if i tap it with a screwdriver a little on the side.
but does it work properly? not sure if it's a fluid of some kind, or just air that expands w/ temp changes - the internal size of that tube is super tiny - why it has to have good contact - no teflon tape or sealer
