0 members (), 116 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#926563 03/11/2013 2:39 PM
I'm at a point in my restoration where I need to replace my radiator. The one it came with is not original plus the thing wouldn't hold water if I put it in. The truck has a 228 GMC engine. My question is this: Does anyone either have a good original radiator that they want to sell or can you recommend a good shop on the west coast that I can get one from. I want to go back to as close to original as possible. Any other advice would be appreciated. Thanks.
Neil
1940 GMC 1/2 Ton
unlikely you'd find a "shop" that had an original 1940 rad, so you might start by checking the repro vendors, the Filling Station has rads - or a post in the parts wanted might find one
Thanks Bill. I've seen shops that can make you one, but it's really going to cost you. The Filling Station has been my primary focus lately so I might just bite the bullet and have their vendor make on for me and save a couple hundred $$. I just don't know if these radiators are still out there and available from someone who upgraded during their resto. I'll take your advice though and hit up the Parts Wanted section before I pull the trigger on a new one. Thanks again.
Neil
1940 GMC 1/2 Ton
I just thought of Filling Station cuz they're west coast, might be others that'd have'em .... but yes, I'd take some time hunting for used original, swap meet season is on in CA wink
I have an original radiator for a 1940 gmc that could be used to make a pattern from. The GMC radiators were different from the chevy radiators of the same years. The GMC radiator has a "Funky" fill/ pressure elbow that pushes the outlet past the front top core support.
