0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 1 Moderated | | Moderated Joined: Mar 2013 Posts: 1 | I have a 49 Chevy 3600 with a locked up engine. Ideas to replace it.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Another 235 or better a 261 if you can find one.
Drew
| | | | | Joined: Aug 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 50 | I replaced the 216 in my 48 3/4 ton with a chevy 250 cu in engine. THe original 216 (which had a bent rod) was 85 hp and the earlier 250 (mine is a 1967) puts out 155hp which is a nice upgrade but does not over power the truck using the stock tranny and rear end. The 250 bolted up to the oringinal 4 spd. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | 230s and 250s are hard to mount. takes alot of work.
id go with a 235 or a 261 like drewp said
there is a 55 235 in greyslake ill. and a 1959 impala 235 in wilminton right now
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Check out the Inliners site. They usually have guys selling engines & parts. | | |
