0 members (), 120 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
#926302 03/10/2013 6:20 PM
What does one do with an ugly beltline crack on a 52 3100? The top groove is nice sheet metal smooth but the bottom crack ( I guess where the top of cab is mounted onto lower part of cab) is awuful looking. I tried filling it but when u shut the doors, the paint cracks. What to do? Weld it smooth might work but it's a little late for that for me.
'52 3100 "once a Marine, always a Marine!!
How about some type of flexable sealer?
That crack is supposed to be there. I cleaned mine out with a dental pick and sanded by hand as deep as I could get. If you are trying to get it smooth like the top of the belt line I don't believe it will ever happen.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
yes, what they said - you might try pumping a good seam sealer in there, but paint will likely always crack from the flexing so don't try to get it rounded like the top edge, use a tool to smooth it concave so it doesn't show
Thanks guys. That's what I thought. I may try a flexable sealer. I sanded it and repainted the area after using a dremel tool to clean out the filler I had in there that was cracking along with the paint, but it still looks terrible. A black sealer would work/look good on this truck i think. Now to find an appropiate sealer.
use 3m seam sealer it is flexable and you can paint it
when the trucks were new what did the factory use?
Denny G
Sandwich, IL
