5 members (Opelika Tom, Otto Skorzeny, MikeE, Wayne67vert, TexasA&M48Truck), 62 guests, and 0 robots.
Topics128,091
Posts1,056,037
Members48,433
#926288 03/10/2013 5:20 PM
My '39 JD is leaking a little oil from the right axle/wheel assembly. The differential appears full. Oil appears to be moving from the transmission down the torque tube, and then out the wheel/axle. The only vent that I can see is on the torque tube, and I suppose it could be blocked. Is that vent threaded into the torque tube, and should I add a vent to the differential or rear axle housing??
The torque tube and axle housing share the same air.
I believe the vent is threaded in on a 39.
My Blog
Dave,
I'll crawl under it in the morning, and gently see if it will come loose.
Many thanks.
Gary
...doncha think it's transmission oil leaking past the torque tube top seal and draining down to the diferential and out past the rear axle seals ?
Yes, I do think the oil is migrating from the transmission to the differential. If, however, the vent is plugged, that may exacerbate the problem. To the best of my memory (not always so good), I did replace the seal in the torque tube. I'm not very enthused about having to do it again, but...
