4 members (HandyAndy, Jon G, 2 invisible),
148
Mod | | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | My '39 JD is leaking a little oil from the right axle/wheel assembly. The differential appears full. Oil appears to be moving from the transmission down the torque tube, and then out the wheel/axle. The only vent that I can see is on the torque tube, and I suppose it could be blocked. Is that vent threaded into the torque tube, and should I add a vent to the differential or rear axle housing??
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The torque tube and axle housing share the same air. I believe the vent is threaded in on a 39.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Dave,
I'll crawl under it in the morning, and gently see if it will come loose.
Many thanks.
Gary | | | | | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | ...doncha think it's transmission oil leaking past the torque tube top seal and draining down to the diferential and out past the rear axle seals ? | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Yes, I do think the oil is migrating from the transmission to the differential. If, however, the vent is plugged, that may exacerbate the problem. To the best of my memory (not always so good), I did replace the seal in the torque tube. I'm not very enthused about having to do it again, but...
