1 members (dunfire),
92
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | What does one do with an ugly beltline crack on a 52 3100? The top groove is nice sheet metal smooth but the bottom crack ( I guess where the top of cab is mounted onto lower part of cab) is awuful looking. I tried filling it but when u shut the doors, the paint cracks. What to do? Weld it smooth might work but it's a little late for that for me.
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | How about some type of flexable sealer?
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | That crack is supposed to be there. I cleaned mine out with a dental pick and sanded by hand as deep as I could get. If you are trying to get it smooth like the top of the belt line I don't believe it will ever happen. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, what they said - you might try pumping a good seam sealer in there, but paint will likely always crack from the flexing so don't try to get it rounded like the top edge, use a tool to smooth it concave so it doesn't show
Bill | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Thanks guys. That's what I thought. I may try a flexable sealer. I sanded it and repainted the area after using a dremel tool to clean out the filler I had in there that was cracking along with the paint, but it still looks terrible. A black sealer would work/look good on this truck i think. Now to find an appropiate sealer.
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | use 3m seam sealer it is flexable and you can paint it | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | when the trucks were new what did the factory use? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
