7 members (FishinToms53, klhansen, Otto Skorzeny, Southerntruck, Mike B, Robert Crandall, Peggy M),
95
Mod | | | Forums66 Topics128,118 Posts1,056,646 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | I've been following the tutorial on this forum to rebuild the speedometer on the 1942 1/2 ton Chevy I'm working on (even though the one in the tutorial is a GMC). It looks very similar to the GMC one in the tutorial, but when I went to remove the odometer I ran into problems. On this one, in addition to having the shims and a clip holding the odometer shaft in the hole it rotates in, there is what looks to be a small brass bushing that keeps me from being able to just push the odometer shaft further into one of the holes to free the other end of the shaft so the odometer can be removed (as shown by Jeff) from the rest of the speedometer.
Does anyone have information on rebuilding the Chevy speedometers and know what the differences are, if any, from the GMC one used for the tutorial, or if I'm missing something here what it is? Like how do I get the odometer freed from the rest of the speedometer and taken apart? Thanks for any help because I really need to get this done ASAP and I don't have time to send it off to get rebuilt by someone else who specializes in this. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Do you have a picture of it? I'm not quite sure I understand...
Jeff | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | why do you need it so quickly? I drove my truck for 25 years with no speedometer. Unless you have modified your truck, you can rest assured you won't be speeding. | | |
