0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92608 08/12/2005 3:02 PM | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | I'm just looking for an "order of operations" list here. I'm pretty handy with a multimeter and know enough not to lick any bare wires. Got the old beast running again yesterday after restoring the fuel system. Drove it around the parking lot a bit and decided to see if my charge gague was telling the truth.
Pulled the battery cable and it died right away.
In an effort to search for horses instead of zebras, I put it to you, fellow bolters, what are the first things I should look for/replace/smack with a hammer?
-J
It's good to take a lap around the lot even though I know it's running on batteries. (does this make it a hybrid? *grin* THINK of what you could do with regenerative brakes on a 6600lb panel truck!!!! I'd be off the grid in NO time!)
'52 3800 Panel School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind. inside of a dog it's too dark to read. -Groucho Marx
#92609 08/12/2005 3:59 PM | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | How fast wuz the engine running when you pulled the cable? Generators don't charge at idle like alternators do. Your system may be working normally. | | |
#92610 08/12/2005 4:12 PM | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | Well... You're right. I had it at a really fast idle. I'll try it again while I'm giving it some gas. Judging from the amount of dead-end wires and frayed cloth insulation and extra (?) wiring everywhere, I don't have very high hopes though. What I DO have is a fire extinguisher.
I'll report back with results.
#92611 08/12/2005 10:33 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Leave your bat. cables on & get out that V.O.M. your are refering to. It should read about 12 volts before you start it. Start it up & accelerate the engine. The voltage should run up to about 7 volts. If it doesn,t & I assume it,s a GM & not a Ford, Remove the wire from the f term. on the regulator & ground the wire. Than acelerate the engine & see if the voltage goes up. If it doesn,t the generator is bad. If it does the regulator is bad. This is assuming the wireing is working.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#92612 08/13/2005 12:06 AM | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | Ummm say that again?
If the voltage goes up... the generator is bad. If the voltage DOESN'T go up... the generator is bad.
Should I just throw it away now? *grin* I assume the terminals you speak of are in the voltage regulator on the firewall?
Thanks again for your advice. I hope to check this out tomorrow.
-J
#92613 08/13/2005 12:20 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | |
#92614 08/13/2005 5:39 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I had the same problem with my '46.
Grandpa and I pulled the generator and we cleaned up the brushes and armature and popped it back in.
Works like a champ now. | | |
#92615 08/13/2005 6:08 AM | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Item #1: Read the article I wrote about generators/regulators in the Tech Tips section.
2. DO NOT remove battery cables with the engine running! it causes big voltage spikes that damage things. (Especially solid-state voltage regulators in self-contained alternators!) It's not good for mechanical regulators on generator/regulator systems, just not as deadly. I've seen spikes of over 100 volts from a 12 volt alternator.
To polarize the generator, remove the wire from the "Arm" terminal at the regulator, and touch it to the "Bat" terminal for half a second or so. You'll get a medium-sized spark. If you get a BIG flash, the armature is shorted, and it's time for a new generator. Reconnect everything, and start up. The voltage should rise to about 7 volts at the battery terminals at a fast idle if everything is working OK. If not, take the "Fld" wire off the regulator and ground it to the regulator base. Check the voltage with it grounded. Voltage should be above 7 volts, and should rise further if you rev up the engine. If the generator is charging that way, it's time to adjust or replace the regulator. Jerry
#92616 08/13/2005 9:33 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sorry I didn,t explain it good. If the voltage goes up with the field grounded the generator is good. If not it is probably the regulator. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#92617 08/14/2005 6:09 AM | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Couldn't you just clip the meter leads to the terminals on the generator with the engine running to test for a working generator?
#92618 08/14/2005 8:23 PM | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The voltage at the armature terminal of a 6V generator can be anywhere from 1/2 volt to 7.5 volts, and still be within normal performance range. A properly polarized generator, with no wires connected to it will produce about 1/2 volt due to "residual magnetism". Once current begins to flow through the field windings the voltage will rise to about 6.5 volts before the cutout relay points close. Depending on the state of charge of the battery, correct generator output can vary from 6.5 volts to 7.5 volts, and still be within normal range. Unless both voltage and current flow are monitored, any measurement will be an educated guess. The state of charge of the battery has more influence on what the generator does than the regulator. The function of a regulator is simply to prevent overloading of the generator, or overcharging of the battery. Jerry
