6 members (Mike B, klhansen, TUTS 59, Otto Skorzeny, Shaffer's1950, Peggy M), 103 guests, and 2 robots.
Topics128,123
Posts1,056,653
Members48,450
#925908 03/08/2013 9:08 PM
I know that the 2 ring Saginaw 4 speed with the 3:11 first gear is the way to go with 3:55 rear gears. However I have a Muncie 2 ring M-20 with 2:52 first gear. Has any of you had this 4 speed behind a 235? If so what rear ratio did you use? I'm open to all ideas as to which rear end to use.
I thought that 2:20 was one of the other 1st gear ratios for the Muncie M20, M21 and M22
Don you are right about the 2.20 low gear but the two groove input shaft M-20 from 1967 that I have has a 1st-2.52,1.88, 1.46, 1.00. You know what they say "Ya got to run what ya brung". Well this is what I have to use and I'm wondering how this will work with the 235? This was out of a late 60 vette. Wide ratio.
what size tires are do you have on the rear of your truck? and does your truck have a 3:55 rear gear?
I am in the building process now. I was going to use a saginaw two groove but I have this Muncie. I was hoping to find some one here that was running a Muncie like mine so I could pick their brain. No rear end yet but was thinking like a blazer or 70's 1/2 ton. No rear tires. I have installed 6 lug front disks. 47 3100 that will have the street rod look with a 235 and muncie 4 speed that I hope will be able to run at 60-65 mph. Getting off the line may be the issue?
Thanks for the help, Willie
You should be able to find a S-10 rear end with a 3:73 ratio. That will work good with the Muncie and 235. Won't be to doggie getting going and you will still be able to run 60 without running to many rpm's.
Dan, Only thing is that I have 6 lug front disks installed so I want to keep the rears 6 lug. Are the 4x4 s-10 6 lug? I was thinking they are 5. I would think that some of the mid 50s-70s are six lug and would have a 3.36 or 3.73 rear end that should be close to being as wide as the torque tube rear I want to replace. Now I just need to find it. Thanks again for your help.
just to let you know, i think you can do a 3rd member swar with a 55-62 rear.
most were 3.9 but some were 4.11 (ods) and autos were like 3.36 or something high lke that. you can also find the 3.36 56ish truck gear sets if you find a 3rd member for it
