7 members (Peggy M, mick53, cmayna, Lostbuthaulinass, RaNfLaS, Southerntruck, JW51),
181
0
Mod | | | Forums66 Topics128,114 Posts1,056,285 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | I have a 49 --3100 and I want to move my battery from under the floorboard to the engine compartment. Anyone know of a aftermarket battery holder/tray that will fit and where I can buy one? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Summit Racing, Speedway Motors. Most automotive after market supply houses offer them. Pick up a copy of Rod Action or Street Rodder magazine they advertise heavily in there. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | That's on my "to do" list. I'll weld up a simple one out of steel or aluminum angle. I can't decide whether to put it on the firewall or on the inner fender. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I've seen guys pull the batt. bracket off the frame and mount it on the firewall. Grinding some rivets may be required. I've also thought about putting it under the seat. Lots of room under an oem bench seat. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Yeah, but probably not a good idea with the gasses that come of a lead acid nor with the corrosion it can create. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Maybe the lead acid gasses will neutralize the behind-the-seat gas smell. Seriously, what's wrong with the original location? I know they moved them under the hood in 54 on the firewall, but I find that location awkward looking. Another aspect of moving a very heavy item further forward takes weight off the rear wheels. I know its only a few feet, but it makes a difference. This is why hotrodders move the battery to the trunk. I have been stuck on a sloppy wet, perfectly level muddy road in one of these trucks. They need more weight toward the rear.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | .... I have been stuck on a sloppy wet, perfectly level muddy road in one of these trucks. They need more weight toward the rear. that's why they have that big 'tray' on the back, to carry weight  Doug - you could simply get a battery tray from one of the later years that had them originally and paste it under the hood - used is cheapest!! Bill | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've seen guys pull the batt. bracket off the frame and mount it on the firewall. Grinding some rivets may be required. That's what I did.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | ...I know they moved them under the hood in 54 on the firewall... The 1954 and 1955 1st still had them under the floor - they got moved in the 55 2nd. Samantha | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | When I moved the gas tank to the rear, I put a dry cell behind the seat with a cut out switch.
Regular batties give off hydrogen when they charge. I've seen regular batteries explode during charging (and splash acid everywhere), so unless you buy a battery designed to be vented & vent it, I wouldn't put it in the cab.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Millions of Volkswagens ran billions of miles with the battery under the back seat.
That said, I see no reason to remove it from it's original location on an AD. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Millions of Volkswagens ran billions of miles with the battery under the back seat.
That said, I see no reason to remove it from it's original location on an AD. Yup. In addition, late model Cadillacs and Buicks are running the battery under the back seat as well.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I can't decide whether to put it on the firewall or on the inner fender. I wouldn't put it on the inner fender as it's to heavy, the inner fender is not strong enough to handle the weight of a bouncing battery. Mike B  | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I was thinking of bracketing off of the radiator mount? And maybe picking the support rod? Dunno. I'm not at that point yet.
I kinda don't want to see the firewall tear out, either. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | [quote=johntsmith]When I moved the gas tank to the rear, I put a dry cell behind the seat with a cut out switch.
Me too, use a Optima battery seal it up and forget it. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...I see no reason to remove it from it's original location on an AD. Me either. I've made a whole bunch of changes on my truck and leaving the battery where it was is a no-brainer, it's actually a nice handy place for one. I didn't have a good original box/tray and wanted a little larger one so I'm using one of the stainless drop down boxes sold by the aftermarket/hot rod shops for these trucks. In my other truck I made the original longer by moving one bracket back and making a new bottom. Grigg | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | [quote=MNSmith]I can't decide whether to put it on the firewall or on the inner fender. I wouldn't put it on the inner fender as it's to heavy, the inner fender is not strong enough to handle the weight of a bouncing battery. My 62 had it on the inner fender when strictly stock. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I made the battery "box" for mine out of 2"x2" steel angle iron and mounted it to the firewall. I didn't want the battery under the box or bed, or behind the seat. A friend of mine had the battery on his AD behind the seat, it caught fire while he was working under the truck in the garage one day and did a lot of damage to his truck. I'll never have a battery in the cab. | | |
