5 members (1955 1 Series, Shade Baby, Oswald, Wayne67vert, Ponchogl), 110 guests, and 3 robots.
Topics128,261
Posts1,058,345
Members48,485
#925671 03/08/2013 1:32 AM
I want to put in new steering column,Ididit,Flaming River etc.I am wondering if there is enough room to use column trans shift version.Anybody done this? Any info/advise greatly appreciated.Thnx
You going to hook that to the original gear box? The shaft on the '39 is part of the gear box and doesn't come off with out a hack saw.
Joe
sooner #925729 03/08/2013 10:16 AM
Is your truck stock or rodded ? Planned motor / trans combination ? Manual or power steering ?
1940 Chevy KC 1/2-Ton
Sorry guys,I should have included more info.TCI IFS,power rack, front end,Small block chev and Turbo 400/350.Would prefer column shift over floor.Thnx
No problem..... I have a column shift type steering column from a 78 Chevy van in mine - hooks up OK to the linkage on my TH350. Have a few Borgeson universals to route DD type steering shaft around exhaust and engine mount, and into the steering box. Have a Saginaw type PS pump with pressure reducer, feeding the M2 rack. Ignition switch is mounted in dash, but no reason you could not mount on column if you choose ( or go with one of those fancy push buttons ! )
i put one from a 84 reagal in my 35 truck with the column shift hooked up to a 700r4. you have to mod the shifter on the trans and play with the linkage or buy the kit from lokar
