0 members (),
140
0
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 41 | I want to put in new steering column,Ididit,Flaming River etc.I am wondering if there is enough room to use column trans shift version.Anybody done this? Any info/advise greatly appreciated.Thnx | | | | | Joined: Feb 2000 Posts: 5,264 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,264 | You going to hook that to the original gear box? The shaft on the '39 is part of the gear box and doesn't come off with out a hack saw.
Joe | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Is your truck stock or rodded ? Planned motor / trans combination ? Manual or power steering ? | | | | | Joined: May 2006 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 41 | Sorry guys,I should have included more info.TCI IFS,power rack, front end,Small block chev and Turbo 400/350.Would prefer column shift over floor.Thnx
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | No problem..... I have a column shift type steering column from a 78 Chevy van in mine - hooks up OK to the linkage on my TH350. Have a few Borgeson universals to route DD type steering shaft around exhaust and engine mount, and into the steering box. Have a Saginaw type PS pump with pressure reducer, feeding the M2 rack. Ignition switch is mounted in dash, but no reason you could not mount on column if you choose ( or go with one of those fancy push buttons ! ) | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i put one from a 84 reagal in my 35 truck with the column shift hooked up to a 700r4. you have to mod the shifter on the trans and play with the linkage or buy the kit from lokar | | |
