| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | So my shifter knob, original, gave up the ghost and broke while I shifted into second the other day. I am unsure of how I should install the new one. It looks like a press fit, but I broke a new one already trying to tap it on with a rubber mallet. Should I heat it up and press it on?
58' 3200 235 3-speed/OD
| | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Have done mine a couple of times. Yes, it is a press fit.
Warmed mine in a coffee cup filled with hot water, so your instincts are good.
Best
Jim | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Alrighty, will do. Thanks Fourbrads!
