9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 20 New Guy | | New Guy Joined: Jul 2010 Posts: 20 |  The driver door should lock by pushing inside handle forward, correct? My driver door opens and closes nicely but does not lock. I do not see a difference in how the latch moves or looks compared to passenger door. Passenger side locks correctly with the key. Is there some adjustment point or does latch need replacing?
Blue51
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, both sides should act the same, need to open the panel and inspect how things move, there are springs involved in both the remote and the latch - no adjustment I know of but something might be worn, broken or out of place, particularly if the outside handle sags
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Driver side gets a lot more use than passenger side. One of the great challenges with these trucks is getting doors to align and work properly. After 60+ years there can be wear on the latch, door or cab or both. You also get wear on handles and linkage. Check all the parts carefully for operation, damage etc. they are pretty robust and new parts are available (not as robust). Good luck! | | |
