| | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92534 08/04/2005 2:31 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Anyone out there ever seen this ultra HEAVY DUTY dist. cap/coil set up for Chev/GMC truck that has a threaded dist cap for these screw in wire ends????? I ran across this first at a swap meet years ago, fits the GM Distributor but this cap has threaded holes for the plug wires? I'm looking for these threaded ends that screw into the cap, only need a couple. Anyone?????? | | |
#92535 08/04/2005 2:38 PM | Joined: Feb 2004 Posts: 29,888 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,888 | Try an aircraft maintenance facility. The submersible ignition wires used on some military vehicles are almost identical to the high-altitude sealed wires used on aircraft engines. Same threaded connectors, I think! Jerry
#92536 08/05/2005 5:04 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | The distributor is probably from a M135 or M211 military truck. Both ends of the spark plug wires have threads. The wires and plugs are still available. Do a search on google for military surplus.
Jason
