7 members (dt235sd, Bill Hanlon, bnauman, Ridgeback, Otto Skorzeny, 1955 1 Series, Chris's 46 / 515), 79 guests, and 2 robots.
Topics128,175
Posts1,057,115
Members48,463
What is a good upgrade option for drum brakes on '52 AD3100 ?
I am looking for under floor master cyl booster options. What is a good donor vehicle? I am keeping drum brakes for now. I am ok with a non power brake option as well. My original master cyl is frozen and I need options.
There is so much knowledge on this forum, I can't seem to narrow a search down. Thanks for anyone willing to share.
Riding in the Passing Lane
Most of the specialty supliers have the conversion kits. CPP has a lot of brake upgrade parts.
1972 Chevy c10 Cheyenne Super
When I rebuilt my 52 3100 I installed a dual master from a 67 C10 chevy truck it's a drum drum ap.no power brakes.Also had to get the adaptor to mount it.Now I'm rebuilding a 53 3/4 ton GMC and I rebuilt the original master and installed it.So I guess both options are fine if you're staying with the drum brakes.
Pete
I like the CCP kit I used on my '52. I was able to keep the original cross member but it required modification. I also had to custom locate the proportioning valve to frame of truck. I think the CCP kit is a quality kit. But, seems like more than what you want to tackle.
Thanks Fellas !
Do you have a part number for the kit?
mr mahoney, PirateJack offer's a great under floor dual master cylinder/booster kit that comes with the brackets and pedal ect. This is a great set up and if you ever decide to go disc your all set up. It is a nice bolt on kit and was fairly priced when I got mine back a year or so ago. My experience was they're nice folks to deal with and may even offer a discount. They are located in Asheville,N.C. which is not far from Tenn depending on where your at.
Good luck regardless of what you decide.
